Results 1 to 7 of 7
Thread: Lisps that will rotate text within a dynamic block
    2015-10
    73
    Default Lisps that will rotate text within a dynamic block
    Hey all, I'm wondering if anyone has run across a lisp routine that will rotate text within a dynamic block. I have the flip dynamic built into the block, but we have 1000s of these blocks in our drawings. It would save TONS of time if we could pick and go.
    I found a LISP that numbers the text within the block in a "pick and go" manner and it's saving lots of time.
    Any how TIA.
    Turlock, CA
    6,419
    Default Re: Lisps that will rotate text within a dynamic block
    Are you saying that your dynamic block isn't capable of doing what you want? Maybe what you really need is help with your block? Anyway, it would be helpful if we had an example or at least a picture of what you're trying to do.
    C:> ED WORKING....
    LinkedIn
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Maybe post one of the blocks and show how you want to rotate the text.
    AutomateCAD
    2015-10
    73
    Here's what I'm striving for. The block has a flip/rotate dynamic, it just takes a little extra time to orient. My hope was for a LISP that would flip the attribute automagically.74.jpg
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Like peter requested nobody's going to be able to code modifying that block without you attaching it for us to test the code on.
    Turlock, CA
    6,419
    Also, there is no such thing as "automagically' when it comes to programming. You have to tell it exactly what to do. That means you have to tell us exactly how it would perform and under what conditions. "When I do this, it should do that".
    C:> ED WORKING....
    LinkedIn
    2015-10
    73
    I would like for the attribute in the block to flip 180 degrees when tapped. I was lucky enough to find a LISP that incrementally advances the number of the attribute by a given factor when you touched the block. I was hoping to find something like that. I know I'm asking a lot considering that what I have works. It was just a hope that somebody had already run across something like this.
  1. Lips to delete all fines in a folder, older than 6 months.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2019-05-22, 07:38 PM
  2. Merging two LIPS routines in one
    By pablogr_medina711431 in forum AutoLISP
    Last Post: 2015-10-23, 09:01 PM
  3. Autocad Lips to copy dimension text tol clipboard
    By TheDetailer in forum AutoLISP
    Last Post: 2013-02-12, 08:11 AM
  4. Lips routine for special Array
    By ionutste in forum AutoLISP
    Last Post: 2012-04-03, 07:16 AM
  5. Dynamic Block within a dynamic block?
    By pbrumberg in forum Dynamic Blocks - Technical
    Last Post: 2006-02-16, 07:05 PM
