Results 1 to 8 of 8
Thread: Architectural Dimensions
    2009-11
    Raleigh, NC
    944
    Default Architectural Dimensions
    How can I get the dimension below to show as 7'-0"
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: Architectural Dimensions
    Look for the "Zero Suppression" setting in the Dimension Style (Primary Units tab) and uncheck "0 inches".
    2009-11
    Raleigh, NC
    944
    Quote Originally Posted by CAtDiva View Post
    I cant get "Zero Suppression" to be edited.
    Any ideas why its grayed out?
    Turlock, CA
    6,421
    I think you will need to post a dwg with the problem, so we can check it.
    C:> ED WORKING....
    LinkedIn
    2009-11
    Raleigh, NC
    944
    Where do I upload a DWG?
    - - - Updated - - -
    Turlock, CA
    6,421
    When replying to a post, click on the Go Advanced button. Then use the Attachments browser to find the file and upload it.
    C:> ED WORKING....
    LinkedIn
    2009-11
    Raleigh, NC
    944
    As I was reducing the size of the drawing it occurred to me why. The Unit Format "Architectural" will not allow it.. Come to think of it, I want to Add -0", not suppress the -0".
    2015-10
    442
    Quote Originally Posted by tim_newsome View Post
    Check the individual properties of the dimension ... based on the snip you showed, the dimstyle is already set for you, but that can be overridden individually (just like other dimension properties).
  1. Replies: 0
    Last Post: 2013-04-08, 08:35 PM
  2. Replies: 0
    Last Post: 2013-03-30, 02:04 AM
  3. Replies: 1
    Last Post: 2008-11-03, 12:01 PM
  4. Revit MEP VS Revit Architectural for architectural
    By schrodingerscat in forum Revit MEP - General
    Last Post: 2008-09-24, 06:58 AM
