Thread: Move\Copy
    Wish List Administration
    2011-08
    4,581
    Default Re: Move\Copy
    Summary: Moving objects and leaving a copy behind (aka copy)
    Description: A command that does both move and copy. Or to word it differently. A move that leaves a copy behind. So the user doesn't have constantly toggle between move and copy.
    Product and Feature: AutoCAD - Modify
    Submitted By: jbenway on 04/26/2023
    Turlock, CA
    6,419
    Have you tried the MOCORO command? It stands for Move/Copy/Rotate. Also, if you select an object and click a grip, e.g. the midpoint of a line or insertion point of a block, you can hold the CRTL key and it will do a copy instead of move.
    C:> ED WORKING....
    LinkedIn
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Doesn't the copy command do that already?
    It leaves the original and places copies anywhere you pick.
