Thread: Iso Start Point
    100 Club dervin's Avatar
    2004-07
    Southeastern USA
    103
    Default Iso Start Point
    Cannot place an Iso Start Point in a particular model. Command line says, "Failed to add start point. Start point exists for line. Failed to add Iso Item." The block for the Start Point is added to listed blocks in the drawing. All layers are on. Iso Start Point block is not listed with blocks and is not showing in the model. Purge does not show the symbol. Tried erase all/remove window, shows same amount of items (not finding anything now showing). Unhide does not reveal it. Show All does not reveal it. Was having the same problem in another model but solved it by purging blocks and saving. Other Iso symbols will place in the model correctly.
    2004-07
    Southeastern USA
    103
    Default Re: Iso Start Point
    Here's what I did. Still don't know what caused it. I started a new model, copy pasted from old to new. Deleted the old. Faster than trying to figure it out.
    2004-07
    Southeastern USA
    103
    Spoke too soon. As soon as I renamed the new model to the original name, the Start Point disappeared and I have the old problem again.
    2004-07
    Southeastern USA
    103
    I had to change the line number to make it work.
  1. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  2. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  3. Replies: 0
    Last Post: 2010-09-21, 03:45 PM
  4. Layer Iso / Un-Iso
    By jas in forum AutoCAD General
    Last Post: 2007-07-24, 05:19 PM
Tags for this Thread
