Thread: Window/ door tags
    2023-05
    5
    Unhappy Window/ door tags
    For some reason, my window and door tags all of a sudden appear HUGE when I click them. This happens on random drawings and I don't know how to fix it. I have audited and purged to no solution. The only way I can fix it is by erasing all my tags and retagging the doors and windows. After retagging them it can be working for DAYS perfectly fine and then boom HUGE again.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: Window/ door tags
    They have multiple annotative scales assigned to them which become visible when the tag is selected.
    For more information on annotative objects in ACAD, you can start here: https://help.autodesk.com/view/ACD/2...8-F9FF084017C6.
    2023-05
    5
    Thank you for this. That link only explains to me what it is. Would you happen to know how to fix it?
    Thanks in advance
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Are you using annotative scales? If not, then setting the block to not be annotative should work. I believe that is in the block definition.
    2023-05
    5
    Yes. there are annotative because they are associated with the windows.
  1. Door Tags Rotate when Door Moves?
    By fletch97 in forum ACA General
    Last Post: 2009-04-23, 12:15 AM
  2. Door tags with room tags.
    By boofredlay in forum Revit Architecture - General
    Last Post: 2006-09-12, 02:18 PM
  3. Door Tags remain after Door Curtain Panel Switch
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2006-05-04, 04:00 PM
  4. Want to tie in Door Tags with Room Tags
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2005-04-14, 01:31 AM
  5. Window/Door tags...dumb question...
    By Kroke in forum Revit Architecture - General
    Last Post: 2004-01-28, 10:19 PM
Tags for this Thread
