Thread: Remove project from Project Manager without deleting the project
    100 Club dervin's Avatar
    2004-07
    Southeastern USA
    103
    Default Remove project from Project Manager without deleting the project
    It appears that Autodesk has not provided a way to remove projects from the Project Manager without deleting the projects. I want to be able to select a project (one at a time) in Project Manager and remove it from the list but not delete the project from the network server. If not, it should be possible. You cannot work forever and continually build up projects in the Project Manager. I can't believe you didn't provide a way to manage it in "Project Manager". It's more like a model and drawing manager than a project manager.
    2004-07
    Southeastern USA
    103
    Default Re: Remove project from Project Manager without deleting the project
    In Plant 3D Project Manager, does right-click project name, close project, only remove from project manager list? I want to only remove from Project Manager list but leave all the project files on the server.
    6,517
    Caveat, I don't use P3D. I did some research, and I doubt that closing a project would delete files. You should be able to reopen a project by browsing to it's project file. You can test this by creating a test project, adding a file (make a copy of something), and then closing the test project. Browse to the folder where it was to see if the files were deleted. I installed P3D and opened and closed the Sample Project several times.
    LinkedIn
  1. Split walls without deleting hosted openings
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2019-10-04, 06:30 PM
  2. Remove Model warning when deleting a layout tab.
    Last Post: 2017-03-20, 12:11 PM
  3. updating link: error cannot be ignored without deleting what?
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-03-01, 05:50 PM
  4. Replies: 2
    Last Post: 2007-06-12, 12:20 PM
