Thread: Point File Formats
    2009-11
    Raleigh, NC
    973
    Default Point File Formats
    What and why is the pencil with the red subtraction logo beside the "External Project Point Database"?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,193
    Default Re: Point File Formats
    Have you connected it to an Access database?
    2009-11
    Raleigh, NC
    973
    I did not. Can I just delete it?
    Is it a format I can create again if I do need to use an external database in the future?
    2002-01
    jUSt Here (a lot)
    9,193
    It comes in the OOTB template. If you are not modifying and overwriting that particular file, then yes, you can delete it. You can overwrite the original OOTB template file if you don't want that setting to return. However, every install of the software would or should have a copy of that template.
  1. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  2. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  3. File Formats (was>Nothing to do about anything, perhaps.)..
    By rookwood in forum Revit Architecture - General
    Last Post: 2005-04-30, 07:12 PM
  4. Replies: 8
    Last Post: 2005-01-19, 07:51 PM
  5. export file formats not offered
    By crater59 in forum AutoCAD LT - General
    Last Post: 2004-11-22, 09:10 AM
