Thread: Outer Boundary
    Raleigh, NC
    944
    Default Outer Boundary
    Is there a method or trick to keeping an outer boundary for a surface for keeping the TIN from losing its association when adding new vertices to it?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Outer Boundary
    How are you adding new vertices to the boundary? Assuming you are using a closed polyline, if you change that polyline to where AutoCAD provides it a new handle or ID, then the association will be lost. This could be from exploding it, or converting it to a feature line or different object type.
    100 Club judekw's Avatar
    2003-09
    Burton, Texas
    129
    Do you have your surface set to Rebuild-Automatic?
  1. 2015: corridor extents as outer boundary - shrinkwrap boundary
    By tott700763 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2015-09-15, 02:24 PM
  2. outer and inner
    By gcameron in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-12-11, 07:54 PM
  3. Replies: 1
    Last Post: 2006-06-28, 09:12 AM
  4. Zoom to Outer Space
    By matt.98118 in forum Revit Architecture - General
    Last Post: 2006-03-29, 05:10 AM
  5. Removing outer leaf of brickwork
    By kimheaver in forum Revit Architecture - General
    Last Post: 2004-09-02, 01:55 AM
