Thread: Complex 3D shape
    2022-06
    Suburb of Fresno
    7
    Default Complex 3D shape
    I am tryinig to draw the front of a roof on a model railroad car. This is a parabolic shape in 2 dimensions. I can't use either EXTRUDE or REVOLVE because they only (apparently) work on a circle, not a parabol.
    I'm using AACAD 2022.
    I've attached a drawing that has two roof fronts. One is the parabolic mentioned above, the other is a pointed roof front.
    For those of you that are railroad nuts, these go on McKeen doodlebugs. They used both the parabolic and a knife-edge front on their cars. I have drawn 13 types of these cars that I want to 3D print and produce for sale. I'd attach a PDF of the "family" but it's 8mb!
    If I can't do this in regular AutoCAD, can you reccomend which version of AutoDesk I should look at?
    2005-06
    in the upper right corner
    3,495
    Default Re: Complex 3D shape
    Quote Originally Posted by sierrabert View Post
    I'm not a 3D Acad expert, and maybe you've tried this, but why don't you 1) create your front and side shapes as closed polylines (while in the proper USC's) and 2) extrude them through each other.
    Then 3) use the "intersect" command, which welds what overlaps and removes the rest.
    My example is very crude but you could make the shapes whatever you need, also look into other 3D commands such as subtract, etc
  1. 2016: drawing a complex spherical 3d shape
    By n.mostofy731732 in forum AutoCAD General
    Last Post: 2016-07-13, 06:12 PM
  2. "Undefined shape" but no missing shape file?
    By cheshirecatfish in forum AutoCAD General
    Last Post: 2012-01-04, 04:42 AM
  3. Replies: 0
    Last Post: 2010-03-12, 05:59 AM
  4. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 01:36 PM
  5. Add Shape file too Complex Linetype
    By Animesh Kundu in forum AutoCAD Customization
    Last Post: 2006-03-22, 08:54 PM
