Thread: Viewport copy from tab to tab
    2009-11
    Raleigh, NC
    922
    Default Viewport copy from tab to tab
    When i copy a viewport from tab to tab it loses its layer state even when the viewport is locked.
    Is there a way to keep the layer state?
    2009-11
    5,709
    Default Re: Viewport copy from tab to tab
    Quote Originally Posted by tim_newsome View Post
    What happens when you apply the Layer State to the drawing, instead of the Viewport and remove all Viewport overrides?
    Computer Specs:
    2014-08
    441
    HI
    never do that anymore. I copied a tab that had a viewport with an error in it several times then discovered the error. the fix at that time was more painful than the extremely long regen times.
    Note to self always make a new veiwport in all new tabs
    2005-06
    in the upper right corner
    3,494
    Quote Originally Posted by BlackBox View Post
    Agreed, I rarely, if ever use VP layer overrides, it can get cumbersome.
    I know Autodesk has given us these many ways to do things, but I keep the MS stuff the way I want it to look/print (with the exception of freezing per VP in some cases)
    We use a lot of xrefs with the layers manipulated when needed (visretain = 1)
    And with that, you can copy viewports across layouts and get what you expect.
    (my 2 cents)
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  3. switch between last layout tab and model tab?
    By unjust in forum AutoLISP
    Last Post: 2012-06-19, 06:27 AM
  4. Viewport copy - viewport On is off
    By vandelay in forum AutoCAD General
    Last Post: 2008-01-11, 12:15 PM
  5. Model tab vs Modelspace via Layout tab?
    By wallnerme in forum AutoCAD General
    Last Post: 2006-07-17, 08:13 AM
