Thread: "Ribbon does not have any tabs....."
    Raleigh, NC
    941
    Default "Ribbon does not have any tabs....."
    This is the third time this has happened on startup and it occurs randomly.
    Any ideas what is causing this?
    6,409
    Default Re: "Ribbon does not have any tabs....."
    Do you have a workspace set as current?
    LinkedIn
    5,719
    Consider the /w (workspace) command line switch in your application icon's shortcut:
    https://help.autodesk.com/view/ACD/2...C-0D4E1EDF093A
    If that doesn't resolve the issue, then check your SFSP in OPTIONS; your main CUI or it's required reference .DLL are not found together in the same folder.
    HTH
    6,409
    Additionally, it doesn't hurt to have a backup cuix for the worst-case scenario if yours gets corrupted. It's happened to me once or twice. Go to the Start Menu and run the Export AutoCAD Settings tool. You can then easily get back to square one with the Import tool.
    LinkedIn
  1. Replies: 20
    Last Post: 2015-05-16, 12:14 AM
  2. Rectangular Eccentric duct transitions does any one have any??
    By pporter in forum Revit MEP - General
    Last Post: 2010-08-11, 09:39 PM
  3. Ribbon does not have tabs loaded?
    By S_Newton in forum AutoCAD CUI Menus
    Last Post: 2009-07-23, 04:49 PM
  4. Replies: 7
    Last Post: 2007-09-26, 08:53 PM
