Thread: Getting cut plane correct for window displays
    2002-03
    Sacramento Ca.
    424
    Default Getting cut plane correct for window displays
    I'm trying to figure out how to get my windows to display correctly in plan view when I raise them above the view range cut plane and use a plan region with view range cut plane set to different height.
    I've tried every conceivable cut plane height in my plan region but all I get is an empty rectangle for my window display. Is there a formula for knowing what height to use for a cut plane to get all of the components to display? Currently using a fixed transom window that displays fine if I lower it in the view to within the view range cut plane.
    2005-06
    in the upper right corner
    3,492
    Default Re: Getting cut plane correct for window displays
    Quote Originally Posted by vanderloo5 View Post
    I'm not an expert on this (I do structural), and I don't know what you mean by a "use a plan region with a cut plane set to a different height" but....
    Why can't you set your view range deeper (higher than the window cut plane and down to where you need it at the floor) with the cut plane at the windows where they are?
  1. Getting window trim to cut through compound wall trim or sweep?
    By Nasko in forum Revit Architecture - General
    Last Post: 2013-02-14, 04:49 PM
  2. Window familie not getting cut
    By adaf997367 in forum Revit Architecture - Families
    Last Post: 2011-06-09, 10:54 AM
  3. Error: Top clip Plane is set Below the Cut Plane
    By hutch_amit in forum Revit Architecture - General
    Last Post: 2008-07-14, 05:11 PM
  4. families not getting cut through/getting cut through
    By rjcoolpix880 in forum Revit Architecture - General
    Last Post: 2006-12-05, 06:04 PM
  5. visibility of windows not cut by the "cut plane"
    By k.armstrong in forum Revit Architecture - General
    Last Post: 2005-05-02, 01:02 PM
Tags for this Thread
