Thread: Remove association of Data Shortcut
    2009-11
    Raleigh, NC
    922
    Default Remove association of Data Shortcut
    How do I remove association of Data Shortcut so there is no association at all?
    Turlock, CA
    6,301
    Default Re: Remove association of Data Shortcut
    This post might help.
    C:> ED WORKING....
    2009-11
    5,708
    To remove a Data Shortcut from your project entirely, in Toolspace > Prospector tab > expand Data Shortcuts node > then right click a Data Reference and select Remove menu item.
    To remove a Data Shortcut Object from your drawing, simply ERASE the Object in ModelSpace, right click & Delete it from Toolspace > Prospector tab, use MANAGEDATASHORTCUTS Command to right click & Delete, or Promote it into the active document.
    HTH
    Computer Specs:
  1. Automate Working and Data Shortcut Folders
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2013-04-23, 08:59 PM
  2. Broaden Sheet Set Association to include data sources
    Last Post: 2012-12-22, 04:15 PM
  3. Data Shortcut & Autocad Crashing
    By JWB in forum AutoCAD Civil 3D - General
    Last Post: 2009-03-12, 10:07 PM
  4. Data Shortcut problem
    By kyleschmeusser in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-19, 06:25 PM
  5. Project data shortcut for assembly
    By backwoods in forum Civil 3D Wish List
    Last Post: 2005-12-20, 03:47 PM
