Thread: Hi, help pls, how to extract. with Lisp, the NAME of the file of an XREF, but that is inside another XREF
    2023-07
    Default Hi, help pls, how to extract. with Lisp, the NAME of the file of an XREF, but that is inside another XREF
    For example, the main XREF, the one displayed on the screen, is called ONE, but within the ONE file, there was already an XREF, within ONE, called TWO.
    I need to extract that Xref name (TWO) to a variable.
    Please.
    And thanks a lot for the help guys !!!!
    2015-10
    Alhambra
    74
    Default Re: Hi, help pls, how to extract. with Lisp, the NAME of the file of an XREF, but that is inside another XREF
    try this:
    ; GetXrfLst function given name of xref returns list of nested xref names if any
    ; Examples:
    ; (load "GetXrfLst")
    ; (setq lst (GetXrfLst "Xref Name")) ; where "Xref Name" is name of top level Xref in current dwg
    ; Returns:
    ; nil ; if no nested xrefs found
    ; ("Elevator Bank 4" "Stair U") ; sorted list of nested xref names
    ; To get xref path of first element:
    ; (cdr (assoc 2 (tblsearch "BLOCK" (nth 0 lst))))
    (defun GetXrfLst (xrf / _nestedxrefs lst)
      (vl-load-com)
    ; _nestedxrefs function given tblobjname of block xref name
    ; Returns list of nested xrefs if any
    ; From Lee Mac
    ; http://www.theswamp.org/index.php?topic=55684.0
     (defun _nestedxrefs ( blk / enx rtn xrn )
       (while (setq blk (entnext blk))
           (if (and (setq enx (entget blk))
                    (= "INSERT" (cdr (assoc 0 enx)))
                    (setq xrn (cdr (assoc 2 enx)))
                    (= 4 (logand 4 (cdr (assoc 70 (tblsearch "BLOCK" xrn)))))
                    (not (member xrn rtn))
               (setq rtn (cons xrn rtn))
       rtn
     (if
      (and
       (tblsearch "BLOCK" xrf) ; if xref name exists in block table
       (setq lst (_nestedxrefs (tblobjname "BLOCK" xrf))) ; get nested xrefs
      (vl-sort lst '<) ; return sorted list in ascending order
    ) ; defun
  1. 2013: Pls Help!!! Pls...Link Dimension not showing up..
    By limruian in forum Revit Architecture - General
    Last Post: 2014-03-19, 04:10 AM
  2. Little help with LISP PLS
    By Deyan Dechev in forum AutoLISP
    Last Post: 2014-01-29, 04:04 PM
  3. 2014: DWG Nested Inside Detail Comp. > Nested Inside Profile > Nested Inside Window
    By edu.rocha.tavares in forum Revit Architecture - Families
    Last Post: 2013-11-26, 06:46 PM
  4. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  5. extract xref name-path to text file
    By johnccole in forum AutoLISP
    Last Post: 2008-01-25, 12:20 PM
