Thread: Convert "spot elevation on grid" from annotate tool to COGO Points
    2004-06
    Slidell, Louisiana
    963
    Default Convert "spot elevation on grid" from annotate tool to COGO Points
    when using the "spot elevation on grid" annotate tool, is there a way to convert those elevations to cogo points
    to be used in making a surface?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,051
    Default Re: Convert "spot elevation on grid" from annotate tool to COGO Points
    It would be a process to do such, but it could be done.
    You should save your drawing if you need the labels to remain as labels after you are done.
    This is also a partial workflow. You will need to determine some steps as you go along.
    If you have markers on your labels, you might explode the labels. Then make a selection set using the SELECT command using the "P"revious option. This should select all of the entities created from the EXPLODE command, which if I recall are now blocks. You could then WBLOCK this selection set to a new drawing.
    Using this new drawing, you would need to explode the blocks created from the EXPLODE command to get to the simple AutoCAD entities (i.e.: non-Civil 3D entities). Hopefully, you have an AutoCAD Point as part of your label marker. This point should be at the elevation you need to create a new surface.
    Another option may be to create a grid based surface and paste the triangle based surface into it. I don't know on this one, but throwing it out there for consideration.
    2009-11
    5,705
    Changing the Surface Elevation Label Style and a manual explode/wblock or export C3D drawing is the simplest thing to get what you need to build a Surface.
    From a code standpoint, while Autodesk conveniently provides a Surface property for Surface Elevation Labels, they fail to expose the .NET Location property which would make it easier to extract the Surface's elevation at that point easily with LISP using FindElevationAtXY method... Unless you can create a .NET LispFunction or two to help with that ( @RK ).
    Without that, you either need .NET API which is rumored to be jumping from .NET Framework 4.8 to .NET 8, or you'd (even in LISP) need to programmatically explode each Surface Elevation Label in memory to either obtain the Text entity value for the elevation, or extract the marker Block's insertion point to extract from Surface with FindElevationAtXY method.
    Computer Specs:
    2007-08
    69
    Here is a video showing the steps I would use that is similar to Opie's description of workflow: https://youtu.be/HnviYLTnblM I included the step to create COGO Points, but as Opie indicated it is not required.
  1. 2023: Importing just the points in xml file as cogo points
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2023-02-03, 01:40 PM
  2. Improved Osnap for COGO Points
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-11-05, 10:13 PM
  3. exporting cogo points to MX
    By dbutler.144607 in forum AutoCAD General
    Last Post: 2008-05-19, 04:03 PM
  4. Snap to COGO points in LT 2008
    By asehovic in forum AutoCAD LT - General
    Last Post: 2008-04-28, 08:08 PM
  5. Exporting cogo Points to LDT 2005
    By ggoodman in forum AutoCAD Civil 3D - General
    Last Post: 2007-06-29, 02:57 PM
