Thread: Screen half/freeze when opening color table
    2006-04
    9
    Default Screen half/freeze when opening color table
    When I am selecting an object and want to change the color, when the color table opens, my screen freezes right down the middle. I can press Tab/Alt 2 times and it un-freezes that portion allowing me to select a color. Then I have to repeat the Tab/Alt to go back again.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,053
    Default Re: Screen half/freeze when opening color table
    Sounds like a potential graphics card/driver issue.
    Turlock, CA
    6,301
    ...or maybe a corrupt dwg. Try it with a new dwg from acad.dwt template.
    C:> ED WORKING....
    2015-10
    Alhambra
    27
    Try setting Gfxdx12 to 0
    If that doesn’t work try disabling hardware acceleration under GraphicsConfig
  1. 2016: How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
    By jeba_kumar703975 in forum Revit MEP - Tips & Tricks
    Last Post: 2016-06-28, 05:10 AM
  2. ISOLATEOBJECTS to include the option to Lock, Freeze & VP Freeze
    Last Post: 2014-11-08, 06:22 PM
  3. HIDEOBJECTS to include the option to Freeze & VP Freeze
    Last Post: 2014-10-28, 02:20 PM
  4. Screen color vs Print Color vs Screen Color
    By bwiab in forum Revit Architecture - General
    Last Post: 2009-04-27, 02:22 PM
  5. I Freeze Layers on the Sheet but wont Save what I Freeze
    By jrosario in forum AutoCAD General
    Last Post: 2008-02-15, 11:48 AM
Tags for this Thread
