Thread: Check for overwritten dimensions on each layout in a drawing
    2023-07
    4
    Default Check for overwritten dimensions on each layout in a drawing
    Please help!
    I'm trying to convert this AutoCAD lisp routine that works perfectly fine on the current layout to one that will run on each layout.
    It works great on a single layout - but I cannot get it to run on multiple layouts.
    Single layout:
    (defun c:DMO (/ ss en)
      (command "_.layer" "_thaw" "0-DIMOVER" "_make" "0-DIMOVER" "c" "30" "" "")
      (prompt "To isolate dimensions with overridden measurement values,")
      (setq ss (ssget "_X" '((0 . "DIMENSION") (1 . "~")))); ignores no-override ones
      (repeat (sslength ss)
        (setq en (ssname ss 0))
        (if
          (not (wcmatch (cdr (assoc 1 (entget en))) "*<>*")); override containing actual measurement
          (command "_.chprop" en "" "la" "0-DIMOVER" "_color" "BYLAYER" "")
        ); if
        (ssdel (ssname ss 0) ss)
      ); repeat
      (princ)
     ):end program
    Here I'm trying to covert it to run on each sheet, after creating the layer. I can't get it to run past the current sheet.
    (defun C:CLEAN (/ ss en)
      (foreach layout (layoutlist)
        (setvar "ctab" layout)
        (if
          (command "_.chprop" en "" "_layer" "0-DIMOVER" "_color" "BYLAYER" "")
        ); if
      ); repeat
      (princ)
      ^^C
      ); end foreach
    ); end defun
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,094
    Default Re: Check for overwritten dimensions on each layout in a drawing
    The ssget function was getting all of the dimensions...
    It was the chprop function that was causing the problem.
    I converted the dimension entity to an object and used activex to change its properties... see below
    P=
    (defun c:DMO (/ ss en obj)
      (if (not (wcmatch (cdr (assoc 1 (entget en))) "*<>*")); override containing actual measurement
       (progn
        (setq obj (vlax-ename->vla-object en))
        (vla-put-layer obj "0-DIMOVER")
        (vla-put-color obj 256)
      ); if
     ); repeat
     (princ)
    ):end program
    (vl-load-com)
    AutomateCAD
    2023-07
    4
    Thank you Peter!
    It's much closer as it will run through each layout, but it doesn't change the layer of the overwritten dimensions.
    I'm not sure why.
    Dorothy
    - - - Updated - - -
    (progn
    ); if
    ); repeat
    (princ)
    ):end program
    (vl-load-com)
    2023-07
    4
    Disregard last post Peter,
    It works perfect!!!!
    Thank you!!!!!!
  1. Find overwritten dimensions in AutoCAD
    By pkorneszczuk777867 in forum AutoLISP
    Last Post: 2019-02-07, 12:59 PM
  2. For each...next within for each...next
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-05-15, 05:01 PM
  3. Replies: 3
    Last Post: 2007-01-15, 06:12 PM
  4. New files got overwritten
    By tdinh in forum ACA General
    Last Post: 2006-03-17, 12:21 PM
  5. Replies: 4
    Last Post: 2004-10-29, 07:03 PM
Tags for this Thread
