Thread: Need help with font in autolisp
    Default Need help with font in autolisp
    Hello
    Thanks in advance for any one can help.
    I would like and appreciate for some to help modify this file so that it incorporate the aerial rounded font when placing the circle on a drawing, and make it as a single entity. When I place the circle and want to delete one, I have to pick both the circle and the text. It would help if I select the circle to delete and both the circle and the text get deleted. The font I want to use is arial rounded with height of .096in, middle center. I sometimes use as many as 25 circles.
    Thanks for looking at this file
    Sincerely
    Javier
    Default Re: Need help with font in autolisp
    Hi everyone I added the font that I use
    2003-07
    539
    Just make the circle and the text a block.
    Have a look at this save Mulit getvals in a support path as its a library lisp for any code.
  1. Replies: 6
    Last Post: 2014-09-20, 03:54 AM
  2. Replies: 10
    Last Post: 2009-10-07, 05:55 PM
  3. HI! Need Help with Missing Font Styles...
    By CADTigress in forum AutoCAD Customization
    Last Post: 2007-08-30, 06:45 PM
  4. Need help finding this font (refer to image)
    By ajtrahan in forum CAD Management - General
    Last Post: 2006-10-23, 08:46 PM
  5. HELP: need to run 2 Autolisp routine at a time
    By bradipos in forum AutoLISP
    Last Post: 2004-09-28, 01:06 PM
