Thread: display settings size
    2009-11
    Raleigh, NC
    922
    Default display settings size
    Is there a setting in options that controls the buttons as large or small?
    Turlock, CA
    6,302
    3
    Default Re: display settings size
    Not specifically. But if you right click on a program's shortcut and select properties, you can click on the compatibility tab and there is a button at the bottom called (1) Change High DPI Settings. In the next dialog, click the (2) checkbox and change the default from Application to (3) System. Now when you change the system's Display settings, the program will respond to the scale setting.
    C:> ED WORKING....
    2023-08
    London
    3
    System requirements are required for this.
  1. ME433-1: To Display or Not to Display: Understanding the Display Manager in AutoCAD® MEP
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2023-08-14, 03:51 PM
  2. 2021: nvidia control panel - manage 3d settings; recommend settings
    By bensal in forum Revit - Hardware & Operating Systems
    Last Post: 2020-09-07, 01:12 PM
  3. 2012: Make existing dimension settings my current dimension settings
    By cfalcionesr in forum AutoCAD General
    Last Post: 2012-08-02, 05:23 PM
  4. Sun settings VS realtime view settings
    By Maximillian in forum Revit Architecture - General
    Last Post: 2006-11-22, 05:54 PM
  5. Select file dialog boxes to all be the same size/view settings
    Last Post: 2005-12-12, 04:53 PM
