Thread: feature lines
    2004-06
    Slidell, Louisiana
    964
    Default feature lines
    how do you add back a feature line to a surface. I was working on a surface, made some changes, deleted some things and several of my feature lines
    were no longer acting as breaklines, but only a portion of the feature line. I tried adding it back to a surface but it said it was already added. but it was clear that
    a portion of it was not breaking. I wound up just deleting them and recreating them and then adding back to the surface. seems like there should be a better way.
    Cairo - no, not Illinois
    5,061
    Default Re: feature lines
    copy the offending feature line from 0,0,0 to 0,0,0, Erase P, and add the last feature line to the surface.
    2004-06
    Slidell, Louisiana
    964
    thanks cadtag. that worked great.
  1. 2019: TIN lines cross feature lines
    By cadtag in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2019-10-14, 05:46 PM
  2. 2013: Line Types - Hot water lines vs cold water lines vs gas lines
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2014-08-26, 06:26 PM
  3. History feature or time tracking feature
    Last Post: 2013-11-19, 07:56 PM
  4. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
  5. Defpoint Lines / Construction Lines / No Plot lines
    By ykang in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:30 PM
