Thread: Hatch Angle Settings
    2023-09
    Default Hatch Angle Settings
    Hi does anyone know if there is a way to display the angle of line hatch to say 3 decimal places? reason is I need to create a line hatch that is perpendicular to the first hatch. i have attached a screenshot of the hatch angle which says it is 1, but it isnt - it has been rounded off.
    Cheers, Patrick
    in the upper right corner
    3,494
    Default Re: Hatch Angle Settings
    You just need to set your drawing units>angle precision higher.
    2023-09
    Perfect that is the setting! thank you very much!
  1. 2021: Reference Line won't flex to the angle set by an angle parameter
    By robinhillrhca700396 in forum Revit Architecture - Families
    Last Post: 2022-12-20, 05:11 PM
  2. 2017: fenetre d'angle avec et sans angle droit
    By blk000000 in forum Revit Architecture - Families
    Last Post: 2017-10-16, 04:06 PM
  3. 2014: Metes and Bounds Report angle and direction settings
    By twhatley in forum AutoCAD Civil 3D - Parcels
    Last Post: 2015-04-06, 04:41 PM
  4. 2013: MEchanical Settings - Elbow Angle Increment?
    By ccenergy in forum Revit MEP - General
    Last Post: 2012-10-18, 11:07 PM
  5. Replies: 10
    Last Post: 2011-07-01, 02:24 PM
