Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Replace an old block with a new one with the same name
  1. #11
    2001-08
    10
    Default Re: Replace an old block with a new one with the same name
    Sorry Ed, I thought I had. Here it is. Really turned out to be simple.
    (defun C:upd-shtm-block ( / #INS)
    (if (tblsearch "block" "dsbdshtm")
      (command "_.insert" "dsbdshtm=" nil)
      (command "attsync" "n" "dsbdshtm")
    );defun upd-shtm-block
    Mind you, this is for a very specific block.
  2. #12
    2016-10
    6
    This line gives me the following error:
    "dsbdshtm.dwg": Can't find file in search path
    *Invalid*
    I'm not sure what that line is supposed to be doing, it looks like it's not doing anything.
  3. #13
    6,300
    He stated that it was the name of a specific block. You would have to modify the code for your use. The main thing he was showing is the use of the attsync command.
  1. Replies: 1
    Last Post: 2018-03-18, 06:20 PM
  2. Select multiple Reference Name and set one new file path at same time
    Last Post: 2017-10-07, 10:24 PM
  3. Replace existing block definition with new definition of the same name
    Last Post: 2016-10-31, 07:37 PM
  4. Identify blocks with same name and replace them with another block
    By msmith.109036 in forum AutoCAD Customization
    Last Post: 2013-11-12, 04:48 PM
  5. Replace old xref files with a set of new xref files
    By simon_coupland in forum AutoLISP
    Last Post: 2013-05-30, 05:12 PM
