Thread: DXB Imported detail
    Cairo - no, not Illinois
    5,069
    Default DXB Imported detail
    It's been a couple- three decades since I've had to deal with DXB in any context, but one of our structural people sent me a detail drawing that appears to be created by importing a DXB file, of possible imported from HPGL -- nothing in it except line segment (and solids for arrowheads) All the text s nothing except lines e.g. the letter "O" is 20 line segments.
    Any suggestions on how to get this POS into a usable form?
    Turlock, CA
    6,374
    Default Re: DXB Imported detail
    Sounds like it may have been a imported pdf. You might try using PDFSHXTEXT to convert the "text".
    C:> ED WORKING....
    5,069
    Good idea -- that looks like it's doing a decent job of converting the linework into actual text entities, it doesn't seem to recognize the numeral "5", but otherwise it does the job.
    Turlock, CA
    6,374
    It will do a better job if you specify a font that more closely matches the lines.
    C:> ED WORKING....
  1. Repeating detail - can't use a detail with other nested detail components?
    By patricks in forum Revit Architecture - Families
    Last Post: 2011-11-12, 03:35 AM
  2. Ouvrir fichier DXB avec LT2007
    By m.devezeaud in forum AutoCAD General
    Last Post: 2010-01-24, 11:03 PM
  3. Re-associate detail view labels with re-imported detail sheets
    By pgastelum77763 in forum AutoCAD Sheet Set Manager
    Last Post: 2007-01-12, 06:18 PM
  4. help from you guys about DXB
    By jeff_balinnang in forum AutoCAD General
    Last Post: 2005-04-06, 04:43 AM
  5. Autocad detail imported to revit
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-07-26, 07:22 AM
