Thread: Contour labels blacked out in PDF plot
    2009-11
    Raleigh, NC
    922
    Default Contour labels blacked out in PDF plot
    Any ideas why contour labels are blacked out in the PDF plot?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,057
    Default Re: Contour labels blacked out in PDF plot
    Typically that would be caused by the driver you are using to generate PDF files with.
    2014-08
    441
    Quote Originally Posted by tim_newsome View Post
    Hi
    if you are using wipeout the wipeout has the same color as the background which may show up in the plot but not in CAD itself
    2009-11
    Raleigh, NC
    922
    Our plot file uses transparency. The layer style had a transparency factor and that was the issue.
  1. 2016: Topography Contour Labels only on some Contour Lines
    By Duncan Lithgow in forum Revit Architecture - General
    Last Post: 2015-11-19, 09:56 AM
  2. 2015: Pipes In Type Selector Blacked Out
    By bt1101011 in forum Revit MEP - Families
    Last Post: 2015-02-25, 11:22 AM
  3. can i make a contour label that leaves out a single contour?
    By JRBOURNE in forum AutoCAD Civil 3D - General
    Last Post: 2012-08-02, 01:18 PM
  4. A "TIFF" Logo is plotting all Blacked out
    By dallas.leinweber in forum AutoCAD Plotting
    Last Post: 2010-10-19, 02:23 PM
  5. Plans Blacked out when printing
    By tf03 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-01-05, 12:18 AM
