Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: LISP modification request - inverse
  1. #11
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,051
    Default Re: LISP modification request - inverse
    Quote Originally Posted by SWarnock84 View Post
    It's not that it's reporting "incorrectly". It works, but only reports distances to 2 decimal places no matter what variables are changed. We were hoping to alter the code to report to 4 decimal places for when we do precision work.
    I didn't write the original code, and my knowledge is fairly limited - so I'm hoping someone more experienced can pick out why that may be happening.
    Thus far we have changed the precision values to 4, checked UNITS, LUPREC, and other drawing settings to no effect.
    You have seven instances of the RTOS function in this routine. Five of those instances have a decimal precision of less than your desired number of spaces of four. Changing those five instances on my end provided the results you requested in the original post of this thread.
    I would recommend setting the precision as a variable in this routine and then using that variable name in place of these five instances. This will ease precision changes in the future for those instances.
  2. #12
    2017-03
    6
    Ouch - operator error. I guess I missed one somehow? You are correct Opie, and I apologize to all.
    Guess this reinforces why I'm not a coder!
  1. Need a help in modification of lisp. Please update the lisp code as required.
    By brahmanandam.thadikonda762224 in forum AutoLISP
    Last Post: 2018-09-20, 04:12 AM
  2. Modification to a lisp (needs to change the lisp code)
    By nanaji130285733687 in forum AutoLISP
    Last Post: 2016-11-21, 04:45 AM
  3. Replies: 12
    Last Post: 2006-01-10, 09:38 PM
  4. Please HELP: Need "Inverse of a Matrix" routine
    By bradipos in forum AutoLISP
    Last Post: 2005-07-08, 02:40 PM
  5. Inverse mouse for walkthrough
    By overcaffeined1745 in forum Revit Architecture - Wish List
    Last Post: 2003-06-10, 11:14 AM
