I hate this error!
"An error occurred during the sub-divide action. The sub-divide can not be completed."
It gives me no information to allow correction. Just "Too bad, Bub!"
I hate this error!
An error occurred during the sub-divide action message in Revit says it's an error and Autodesk is looking into it.
2024 Toposolid error when attempting to split might have a cause ("it seems that a sketch cannot be created if it cuts through the middle of an elevation point.") and a possible solution " If I use pick lines and offset them 1/8", then the sketch can be created."
It's worth a try. I hope that helps.
PS. Both posts were made before yours, so search the text of your error should have brought them up. That's all I did.
