Thread: Attached lisp can't read Dynamic blocks with attributes but other Dynamic blocks can be read easily
    Default Attached lisp can't read Dynamic blocks with attributes but other Dynamic blocks can be read easily
    This lisp for selecting last added items in the drawing so , when you try to apply that lisp with dynamic blocks with attributes it will not work but it will work with any other objects
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Default Re: Attached lisp can't read Dynamic blocks with attributes but other Dynamic blocks can be read easily
    Use acdb reactor instead of entlast to avoid this.
    This code is really hard to understand (for me) just because of the comments.
    I would use the acdbappended reactor to add items to a list of new entities and then use the command ended reactor to iterate through the new items...
    P=
    AutomateCAD
  1. 2015: Structural Framing (other) - can you change (other) to some other Category?
    By troypiggo in forum Revit Structure - General
    Last Post: 2014-05-15, 11:11 PM
  2. Replies: 5
    Last Post: 2013-05-18, 01:44 PM
  3. 2013 Create Blocks with attributes from attached .mdb file
    By dhenderhan378554 in forum AutoCAD Map 3D - Import/Export
    Last Post: 2013-05-08, 01:34 PM
  4. Replies: 8
    Last Post: 2010-11-27, 05:03 PM
  5. Replies: 2
    Last Post: 2007-05-11, 11:25 AM
