Thread: AutoCAD MEP for small residential
    2016-05
    2
    Default AutoCAD MEP for small residential
    Hello all
    Curious if anyone has been using MEP for small residential jobs (row housing, stacked townhouses, duplexes, etc.)? I’m wondering if there is any productivity improvement on smaller jobs where I’d be doing MEP for the whole building but the building is 6-9 residential units with maybe 2-3 different floor plans. Not sure if the training and setup time is any faster or beneficial than drawing the systems manually.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    445
    Default Re: AutoCAD MEP for small residential
    Is this a one-off situation? Then the setup & training is not worth the time.
    If you're looking at the big picture project tools, it is probably worth it to start with a small project and work out some kinks before going to a large project. Just make sure to differentiate between actual project time and learning/setup time.
    But on the looking forward front, I would hesitate on the AutoCAD MEP and consider transitioning to Revit instead.
  1. 2016: Tactics on Small Residential Drainage
    By Sterling2017 in forum Civil 3D Tips & Tricks
    Last Post: 2019-06-05, 01:32 PM
  2. MEP Analysis Extension for AutoCAD MEP/Revit MEP
    By trythefly in forum Revit MEP - General
    Last Post: 2010-06-07, 10:54 AM
  3. Replies: 0
    Last Post: 2008-12-11, 09:35 PM
  4. MEP Analysis Extension for AutoCAD MEP and Revit MEP
    By kyle.bernhardt in forum Revit MEP - General
    Last Post: 2008-07-10, 05:02 PM
  5. MEP Analysis Extension for AutoCAD MEP and Revit MEP
    By toby.smith in forum AMEP General
    Last Post: 2008-07-10, 01:26 PM
Tags for this Thread
