Thread: subassembly marker style
    2009-11
    Raleigh, NC
    954
    Default subassembly marker style
    How do I decrease the size of the markers on the point of a sub-assembly?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Default Re: subassembly marker style
    It is a style issue. Look at your code set style assigned to the assembly. It should get you to the style you need to make the desired changes to.
  1. Replies: 1
    Last Post: 2018-01-31, 02:45 PM
  2. import and edit built-in autodesk subassembly in subassembly composer??
    By phpa80457421 in forum AutoCAD Civil 3D - General
    Last Post: 2012-08-08, 03:57 PM
  3. Red AutoSNAP marker
    By uros.lesjak in forum AutoCAD General
    Last Post: 2004-06-30, 12:47 PM
  4. Section marker: Anyone know how to create this?
    By John K. in forum Revit Architecture - Families
    Last Post: 2003-12-12, 01:54 PM
