Thread: -blockreplace command line/LISP help
    Default -blockreplace command line/LISP help
    Hello,
    Trying to work with using the -blockreplace command in a LISP.
    I am having trouble forming the command. Can anyone help get me started in the right direction?
    Many thanks.
    Here is what I am trying to execute, but I can't quite get the syntax right to where it will execute from the command line.
    (command "-BLOCKREPLACE" "ANALOG_PT_BLK" _Point Block FD "y" "")
    Overall I have a pretty simple task to accomplish.
    I want to run a LISP that will look for a block and replace it with another block. The block names never change.
    Here is an example of a LISP I was trying to work with.
    (defun c:ReplaceBlocks ()
    (setq fromBlock "ANALOG_PT_BLK") ; Specify the source block name
    (setq toBlock "_Point Block FD") ; Specify the target block name
    (if (tblsearch "block" fromBlock)
    (progn
    (command "-BLOCKREPLACE" fromBlock toBlock "y" "")
    (princ (strcat "\nBlock replacement complete."))
    (princ (strcat "\nBlock '" fromBlock "' not found."))
    (princ)
    Cheers.
    Turlock, CA
    6,409
    Default Re: -blockreplace command line/LISP help
    I just posted a lisp that can replace blocks by several methods. It has several command in it.
    C:> ED WORKING....
    LinkedIn
    2003-07
    559
    (command "-BLOCKREPLACE" "ANALOG_PT_BLK" "_Point Block FD" "y" "")
  1. Anonymous Block Names Stumping SSX and BLOCKREPLACE...
    By swojtynek408932 in forum CAD Management - General
    Last Post: 2013-09-16, 07:52 PM
  2. Replies: 0
    Last Post: 2011-11-23, 03:50 PM
  3. Select Blocks when using BLOCKREPLACE
    Last Post: 2008-10-11, 08:48 PM
  4. Blockreplace in Multiple drawings
    By nicholaskamm in forum AutoLISP
    Last Post: 2008-04-17, 12:34 PM
