Thread: Adding a comma to a label style
    2023-01
    55
    Default Adding a comma to a label style
    Once a distance on a line label passes 999', where do I tell the label style that I want it to put a comma? I can't seem to find that part of the style. Any help is appreciated.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    2
    Default Re: Adding a comma to a label style
    You are searching for Digit Grouping. It is a property of distance/length elements used in the Context dialog of a label.
    2023-01
    55
    Thank you!
  1. comma and decimal in same label
    By gleiper in forum AutoCAD Civil 3D - General
    Last Post: 2010-07-03, 03:53 AM
  2. comma for square footage label
    By gleiper in forum AutoCAD Civil 3D - Parcels
    Last Post: 2010-03-31, 05:29 AM
  3. comma for square footage label
    By gleiper in forum AutoCAD Civil 3D - FAQ (Read only)
    Last Post: 2010-03-30, 02:22 AM
  4. Dynamic Label Button with Preset Label style
    By mike.smith696451 in forum AutoCAD CUI Menus
    Last Post: 2006-06-09, 06:53 AM
  5. Adding comma's to a text box...
    By mike_atwell in forum VBA/COM Interop
    Last Post: 2006-03-22, 03:50 PM
Tags for this Thread
