Results 1 to 7 of 7
Thread: How do I control the Layers of the Elevation Table of a Volume Surface
    2012-09
    35
    Default How do I control the Layers of the Elevation Table of a Volume Surface
    For a volume surface, I can produce an Elevation Table like this, I'm sure we are all familiar with.
    I'm suppose to have the following control over layers
    The problem I'm experiencing is that the Colored Squares (Red -> yellow -> Green) are being associated with a different layer (My companies BORDER layer)
    They only plot in color when that layer's plot style is set to color. I want that layer's plot style to be black, so those squares are plotting black.
    How do I put those little squares on a different layer?
    Thanks.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: How do I control the Layers of the Elevation Table of a Volume Surface
    What layer is the table assigned?
    2012-09
    35
    How do I find that out? I click on it, and it's on the 0 layer.
    2002-01
    jUSt Here (a lot)
    9,106
    If the table as inserted into the drawing is reporting it is on layer 0, I'm not sure how it is referencing the BORDER layer you stated earlier.
    Are you plotting based CTB or STB styles? I'm assuming STB as you are referring to the Plot Style. You might create a new layer with the correct plot style settings and then assign the table to this new layer. Hopefully, this will resolve your issue.
    2012-09
    35
    When you say Assign the table to the new layer, You mean just select it and change it's layer in the properties window?
    Thanks
    2002-01
    jUSt Here (a lot)
    9,106
    Pretty much, yes.
    2003-12
    Washington DC
    5
    Quote Originally Posted by Patrick G View Post
    Thanks.
    Those colors are assigned in the surface properties
    Analysis Tab
    Elevations
    Range Details
    Click there to change the colors
  1. Swap a surface in a .tin volume surface
    Last Post: 2021-10-07, 02:41 PM
  2. 2015: Répercussion d'un paramètre partagé de matériaux d'un volume vers ses sols de volume
    By eric.lehy-meira695599 in forum Revit Architecture - General
    Last Post: 2015-04-22, 10:25 AM
  3. Composite volume versus grid surface volume calculations
    By rschaff in forum AutoCAD Civil 3D - Grading
    Last Post: 2011-10-04, 04:20 PM
  4. Different Layers for Table and Table Text?
    By miket.203279 in forum AutoCAD General
    Last Post: 2010-01-14, 01:29 PM
  5. Surface Volume Table
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-11-07, 09:03 PM
