Results 1 to 8 of 8
Thread: bay window
    2018-03
    52
    Unhappy bay window
    Hi Has any one ever created a bay window that fits in to an AEC wall in AEC model.
    Turlock, CA
    6,525
    Default Re: bay window
    Are you using AutoCAD Architecture? It comes with some bay window styles. Or you can see this post. Search this forum for more posts about bay windows.
    C:> ED WORKING....
    LinkedIn
    2018-03
    52
    Hi Ed
    sorry for taking so long to reply we are so busy
    I am using ACA 2024
    I have not been able to find and bay windows only corner windows,
    can you let me know where they are?
    thanks John
    Turlock, CA
    6,525
    Open the Styles Browser>Type>Architectural Objects>Window and scroll down to the bay window. This is what was referred to in the other thread I linked to.
    C:> ED WORKING....
    LinkedIn
    2018-03
    52
    Hi Ed
    Sorry again for getting back to you it's just crazy at the moment.
    I have checked and we don't have the option.
    We are running AutoCAD architecture 2024
    Turlock, CA
    6,525
    What profile are you using? Imperial, Metric or Global? I'm using Imperial, so it may not be in the other formats.
    I just checked and its not in metric. You can copy the imperial style and modify it to metric.
    C:> ED WORKING....
    LinkedIn
    2018-03
    52
    FOUND IT
    Thanks a lot
    I will play with it later and see if I can remove the roof and sill.
    We are based in Australia and the bay windows normally go from 1C at the sill to 28C at the head.
    and are under the eaves.
    thanks again
    2002-12
    275
    Fellow Aussie here. (5 years later).
    For a bay window I will use two corner windows, stacked so middle window overlaps.
    It does create some display and cleanup issues.
    To be clear, I use a corner window style to create the overall frame and then double up each of the 3 windows with an insertion of an individual window.
    The corner windows I don't schedule. I just use them to cut the corners on the walls. I turn off glass or make it 0 width. It makes a nice corner column.
    Adding additional single windows allows greater flexibility on the style of window, so the two sides might be fixed and the centre, a fixed/slider.
    These are what I schedule, like what happens in real life.
  1. 2013: Problem with inserting Fixed Window into a Bay Window
    By konetarchitecture in forum Revit Architecture - General
    Last Post: 2013-03-24, 07:26 PM
  2. Bay Windows - True Bay Windows cannot be created in Revit or can they?
    By robinhill833400 in forum Revit Architecture - General
    Last Post: 2012-10-03, 03:55 PM
  3. It's the "vertically sloping bay window" project.. :)
    By Paul Monsef in forum Revit - Gallery
    Last Post: 2005-01-14, 03:45 AM
  4. Bay window
    By kimheaver in forum Revit Architecture - Families
    Last Post: 2004-08-02, 04:19 AM
Tags for this Thread
