Thread: Override table cell border property using visual lisp
    2015-01
    47
    Default Override table cell border property using visual lisp
    I'm looking for a vla method I can use on a selected table cell to override the border property, specifically to add a line at the the top of cell.
    I'm assuming it would be a variation on vla-put___ but I can't guess the property name to complete the method, and apparently nobody with access to the internet has ever wanted to override a table cell's border properties before. I'd sure appreciate a helping hand here.
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,114
    Default Re: Override table cell border property using visual lisp
    From AutoCAD ActiveX Reference Guide
    VBA:
    object.SetCellGridVisibility row, col, edges, bValueobject
    Type: Table
    The object this method applies to.
    row
    Access: Input-only
    Type: Long
    The row number of the cell to set.
    col
    Access: Input-only
    Type: Long
    The column number of the cell to set.
    edges
    Access: Input-only
    Type: AcCellEdgeMask enum
    The cell edges.
    acBottomMask
    acLeftMask
    acRightMask
    acTopMask
    bValue
    Access: Input-only
    Type: Boolean
    The visibility of the grid for the cell.
    True: Grid is visible for the cell.
    False: Grid is not visible for the cell.
    AutomateCAD
    2015-01
    47
    That was it! Man, I could have looked for years without figuring that out. Thank you Peter.
    2000-09
    Honolulu HI
    1,114
    3
    This is a lecture I prepared for Autodesk University.
    There are code examples to manipulate tables.
    P=
    AutomateCAD
  1. Replies: 4
    Last Post: 2023-11-09, 09:34 PM
  2. Set horizontal cell margins in a specific table cell
    By deheylen690271 in forum AutoLISP
    Last Post: 2019-06-17, 09:05 PM
  3. Replies: 0
    Last Post: 2013-10-31, 08:42 PM
  4. Moving from cell to cell
    By Grumpy in forum AutoCAD Tables
    Last Post: 2007-11-15, 10:31 PM
  5. Replies: 5
    Last Post: 2006-03-28, 07:27 PM
