Thread: Improve WorkFlow -Exporting from Revit to DWG files 3D elevated views
    2016-07
    5
    Talking Improve WorkFlow -Exporting from Revit to DWG files 3D elevated views
    2016-07
    Using Dynamo I would like to know how to write a script using Dynamo, to enable a workflow to be smoother and less time consuming.
    We have to export our 3D models to DWG files. Open up the DWG file in 3d then elevate our model to the desired elevation.
    and if we have to do 25 floors that is a lot of exporting and elevating. Does anyone have a script or know how to do it using Dynamo?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,138
    Default Re: Improve WorkFlow -Exporting from Revit to DWG files 3D elevated views
    Can you expand on your process to complete the process to elevate one model to the desired elevation? What are your manual steps?
  1. Material cut from concrete column in elevated column schedule
    By khanson-3b in forum Revit Structure - General
    Last Post: 2011-04-10, 06:24 AM
  2. Elevated Subregions
    By Justin344 in forum Revit Architecture - General
    Last Post: 2009-12-02, 05:30 PM
  3. Super Elevated Lane (SA)
    By tim_newsome in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-11-20, 11:29 PM
  4. Elevated slab display - ADT 2006
    By Chuckyd67 in forum ACA General
    Last Post: 2006-08-21, 11:47 AM
