Results 1 to 7 of 7
Thread: Set hatch to use "Current Layer" permanently
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    152
    Question Set hatch to use "Current Layer" permanently
    Hatch Layer "Override".
    I find it often set to a specific layer (must come from our template).
    That just does not work for me. I want it set to "Use Current", permanently.
    Is there a setvar I can put in my startup suite that will set that?
    I often isolate layers for creating a hatch, and if the default hatch layer is off, I create a hatch and don't even know it. Try again. Now I've created a second hatch over the first one that I still can not see. Ahhhhh!
    Eventually I figure it out, unisolate my layers, delete the duplicates, change the layer of the hatch to the layer I had current in the first place, and move on. Again, Ahhhh!
    How can I permanently set the hatch layer to "Use Current"?
    Thanks.
    Jeff
    2009-11
    5,725
    5
    Default Re: Set hatch to use "Current Layer" permanently
    Try setting HPLAYER sysvar to "." (aka current layer) on drawing open.
    You cannot do this permanently per-se, as this is a drawing saved sysvar, but you can add it to SYSVARMONITOR, AcadDoc.lsp, etc which will do the work for you automagically.
    HTH
    Computer Specs:
    2015-10
    23
    Hey Black...
    I tried this but was not successful.
    What is the exact coding I put in? (SETVAR "HPLAYER" ???)
    Thanks, Tom
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    2
    (SETVAR "HPLAYER" ".")
    2015-10
    23
    I did it and it's not working. Is there some type of setting in cad that's preventing it?
    Turlock, CA
    6,488
    You need to provide more specific information than just saying "its not working". Do you get an error? Do you set it and later it gets changed? After you run (setvar "hplayer" "."), run (getvar "hplayer) to check it's value and see if the change is sticking.
    C:> ED WORKING....
    LinkedIn
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,684
    Just enter HPLAYER at the command line and let us know what it returns. You should also be able to set it that way.
  1. 2019: Permanently hiding objects until recalled for use
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2020-04-04, 09:59 PM
  2. Is there a way to set Osnapz to 1 permanently?
    By kwong in forum AutoCAD General
    Last Post: 2018-01-30, 04:51 PM
  3. Permanently set Linetype Generation to Enable
    By avn in forum AutoCAD General
    Last Post: 2015-11-13, 03:59 PM
  4. how to use several DWG files permanently
    By t_khoshzaman in forum Dot Net API
    Last Post: 2010-08-23, 08:55 PM
  5. Permanently set Relative Path as Xref default
    By Globey in forum AutoCAD General
    Last Post: 2008-10-01, 12:23 PM
