Results 1 to 7 of 7
Thread: Bar Scales for Modelspace & Paperspace
    2011-10
    Norfolk England
    57
    4
    Default Bar Scales for Modelspace & Paperspace
    Hi All
    Been Fiddling again!
    I know the latest version of autocad has some form of barscales linked to the viewport scale.
    However I'm sure there are many out there who, like me are using an older version, mess about with barscales and many of you will have already developed your own.
    Here are a couple of blocks for Model and Paper space which I hope some of you will find helpful.
    Please let me know if there are any problems
    Geoff
    Turlock, CA
    6,488
    Default Re: Bar Scales for Modelspace & Paperspace
    I don't think AutoCAD has something out of the box that does that. The tool palettes have a scale bar similar to yours, but I think yours is better. Perhaps you meant something like this?
    C:> ED WORKING....
    LinkedIn
    2013-12
    Geoff:
    Can you help me out on the barscale use.
    I'm using Autcad 2024
    I inserted the .dwg into a drawing I creating and when I dbl-click on the block
    the block editor opens and I see the parameters....
    How do I set it such that the bar scale becomes 1"=100'
    Louis
    2005-06
    in the upper right corner
    3,518
    2
    Quote Originally Posted by LDUENWEG453812 View Post
    Geoff:
    Louis
    You select the block (not double click) and it highlights the pulldown menu - you select that and then pick the scale you want.
    Fun fact, this bar scale "scales up" in MS which I wasn't prepared for. All the bar scales I use are 1:1 PS with different scales (visibility states)
    2011-10
    Norfolk England
    57
    Hi tedg
    I have just done the same exercise and the dwg becomes a block so explode the block and it works OK, also if you copy and paste the barscale it works OK.
    Well it did for me.
    2005-06
    3,518
    Quote Originally Posted by Calteq View Post
    Hi tedg
    Well it did for me.
    True, if you insert it from another file, it's a nested block, explode it once and then it's the dynamic block with all the bells and whistles.
    And if you copy/paste the working block from another file, it should be fine as is.
    2015-12
    Thanks! I hadn't seen a model space bar scale before.
  1. 2 Scales in ModelSpace?
    By jmb.allislandfireprotection in forum AutoCAD Customization
    Last Post: 2010-09-14, 06:58 PM
  2. Scaling the same Modelspace Objects at different scales in Paperspace
    By paul.vanvlasselaer in forum AutoCAD General
    Last Post: 2007-03-28, 06:52 PM
  3. Replies: 9
    Last Post: 2007-01-10, 09:28 AM
  4. Linetype scales between Modelspace and Paperspace
    By dcornelius in forum AutoCAD General
    Last Post: 2006-12-18, 06:22 PM
  5. Object in Paperspace vs Modelspace
    By matt.worland in forum VBA/COM Interop
    Last Post: 2004-07-29, 02:38 PM
