Thread: CUI command is locking/freezing Civ3D
    2009-11
    Raleigh, NC
    962
    Default CUI command is locking/freezing Civ3D
    When I key in CUI the dialogue box is not coming up. I think its hidden somewhere.
    How can I find it or remedy this?
    Turlock, CA
    6,521
    3
    Default Re: CUI command is locking/freezing Civ3D
    Sounds like the dialog is appearing off screen. Press ALT+Space, then M for Move and use the arrow keys to bring it to the visible area.
    C:> ED WORKING....
    LinkedIn
    2009-11
    Raleigh, NC
    962
    This is not working
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,685
    2
    For the CUI dialog box Ed's solution is the only one I've ever seen. Not knowing where it's moved to you're going to have to experiment with those arrow keys a bit.
    https://forums.augi.com/showthread.p...es-in-LDT-2007
    For other dialog boxes I've set coordinates for their in the CUI dialog box as a solution.
    I found years ago that setting my Workspace Settings for "When switching workspaces" to "Do not save changes workspace" that way if a dialog box disappeared simply switching to another workspace then back again put the dialog box back where it was. I've never had an issue since.
    2009-04
    Fort Wayne, IN
    153
    One suggestion I've had mixed success with if you have multiple monitors.
    Move the Civil 3D window to the secondary monitor. Unplug the monitor. This will reset the display back to the primary monitor.
    If you're lucky, the CUI window will move to the primary monitor and reset its location. Like I said, sometimes this works for me, sometimes not.
  1. 2020: Corrupt Civ3D files
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2020-04-23, 04:38 PM
  2. 2016: upgrading to 2018 Civ3D
    Last Post: 2017-01-19, 08:09 PM
  3. Replies: 0
    Last Post: 2013-04-05, 11:39 AM
  4. Replies: 10
    Last Post: 2007-06-07, 12:03 AM
