Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Drawings are super slow with xref's
  1. #21
    2015-10
    Default Re: Drawings are super slow with xref's
    Try setting "XLOADTCTL" to "0". This setting should be changed for any and all users working with the files.
    - - - Updated - - -
  2. #22
    Turlock, CA
    6,528
    I disagree with the author of the blog post you linked to, which doesn't show due to your low post count. But XLOADCTL = 0 turns off demand loading, which is specifically designed to speed up the use of xrefs. Note this quote from the previous linked topic:
    The program uses demand loading and saving drawings with internal indexes to increase performance with large referenced drawings that have been clipped, or that have many objects on frozen layers. With demand loading, only the data from the reference drawing that is necessary to regenerate the current drawing is loaded into memory. In other words, referenced data is read in “on demand.”
    In other words, with demand loading off (XLOADCTL=0), everything in the xref will be loaded into memory, whether it is used visually or not. Due to this, the fastest response times will be when you have XLOADCTL=2, which is why it's the default setting.
    C:> ED WORKING....
    LinkedIn
  1. 2013: ACAD 2013 SP2 Shift-Deselect works, but super slow. Issuing commands is slow.
    By Professor Lavahot in forum AutoCAD General
    Last Post: 2013-08-05, 03:41 PM
  2. Slow.. slow..very slow..Gallery
    By engwaiphyo in forum AutoCAD Gallery
    Last Post: 2009-04-09, 07:32 PM
  3. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
  4. Really odd error after super slow save
    By kathy71046 in forum AutoCAD General
    Last Post: 2008-06-08, 08:51 AM
  5. slow switching drawings and slow commands
    By vance.smith in forum AutoCAD General
    Last Post: 2006-04-28, 05:24 PM
Tags for this Thread
