Thread: Point Style Overrides
    2023-01
    55
    Default Point Style Overrides
    I'm hoping someone can help.
    I seem to be having trouble with my point style overrides, assuming I'm clear on how they work.
    I can't seem to get the file small enough to attach so I just have to describe my problem.
    I have several topo shots, each with their own point code and placed in a separate point group. For example, the points coded as 900 are ground shots and they automatically go into a ground shots point group. However, I would also like them to be in the spots point group and take on that style over the current ground shots point group style. I have tried everything I can think of. Right now I have the style and point label style in the spots group, checked and those same options in the ground shots group unchecked. I thought that would make the points have the spot elevation style. I have also tried any other combination of options that I could come up with and the points maintained the style of the ground shots.
    Am I not understanding the usefulness of the overrides or am I missing something? I would really appreciate the help. Thanks in advance.
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Default Re: Point Style Overrides
    If you Right Click on Point Groups - select Properties, Is your point group you want to use overrides with showing above the Ground Shots point group?
    2023-01
    55
    Thank you!
  1. 2022: point style and label style in xrefs
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2022-04-05, 08:13 PM
  2. Replies: 1
    Last Post: 2018-01-31, 02:45 PM
  3. CV104-1P: One Point, Two Point, Red Point, Blue Point
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:17 AM
  4. CV12-4: One Point, Two Point, Red Point, Blue Point
    Last Post: 2013-04-17, 04:50 AM
  5. 2011: Visual Style Overrides Plot Style
    By CADMariner in forum AMEP General
    Last Post: 2011-06-16, 02:03 PM
Tags for this Thread
