Thread: !!! VBA Excel problems with file path consisting spaces when sending command to Autocad
    2024-05
    Default !!! VBA Excel problems with file path consisting spaces when sending command to Autocad
    I coding VBA excel to send commands Insert blocks to Autocad.
    Filename contains block is C:/Tu Tool/Rebar Detailing/Rebar Detail Block/EUROCODE/Type 21/Type 21-D12.dwg
    However autocad interpret the SPACE in file path as Enter in command line ?
    So have you got any ideas to handle these problems
    Much thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Default Re: !!! VBA Excel problems with file path consisting spaces when sending command to Autocad
    Surround the path with an additional set of quotes.
    Turlock, CA
    6,488
    That won't work. You have to add the extra quote with either an escape character or a third set of quotes. See the examples below. Also, you either need to use vbLf or vbCrLf. vbCr just issues a carriage return.
    ThisDrawing.SendCommand "_insert" & vbCrLf &"""C:\\some path with spaces\\filename,dwg"""
    or
    ThisDrawing.SendCommand "_insert" & vbCrLf &""C:\\some path with spaces\\filename,dwg""
    C:> ED WORKING....
    LinkedIn
  1. Replies: 0
    Last Post: 2018-10-07, 02:12 PM
  2. Replies: 5
    Last Post: 2013-10-16, 05:39 PM
  3. Sending Commands to Command Line From Modal Form
    By Ivan.Markov.206575 in forum Dot Net API
    Last Post: 2009-07-23, 02:50 PM
  4. Detail in Revit and developments consisting every year
    By varnergiuntoli in forum Revit Architecture - Wish List
    Last Post: 2007-06-17, 06:50 PM
  5. Sending text to a printer in VBA (how?)
    By mbeebe9691 in forum VBA/COM Interop
    Last Post: 2004-06-09, 06:52 PM
