Thread: How to change poliline to get the parabolic shape
    2016-10
    2
    Default How to change poliline to get the parabolic shape
    I have a lot of polylines that need to be converted to the vertical parabolic shape of line sag
    and then I want to create a pipe with a small diameter tube along.
    How can I use lisp to select those lines so it will perform the above 2 requests?
    I have attached the reference file below
    Turlock, CA
    6,495
    Default Re: How to change poliline to get the parabolic shape
    The mathematical term for that curve is called a catenary curve. If all you want is 2D lines, then you can use the attached lisp. But if you want actual 3D cables, then you will need a much more robust solution. I recommend AUD from Spatial Business Systems.
    C:> ED WORKING....
    LinkedIn
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,684
    In roadway design vertical parabolic curves for elevations are the standard used in Civil 3D to create profile sections.
    You should be able to use that for the profile sections with straight segments in the plan views.
    One of the 3 types of curves described in Civil 3D help: https://help.autodesk.com/view/CIV3D...5-D18C60F9ECCB
    See also: https://help.autodesk.com/view/CIV3D...6-7A1D6288D7A1
    2016-10
    2
    How I can use this lisp? What input "Tension in the cable & cable weight per unit length"
    I only want to change to a catenary curve.
    - - - Updated - - -
    See also:
    How to I change multiple line, I don't want create profiles sections because I have a lot of polyline.
    Turlock, CA
    6,495
    Quote Originally Posted by dien2708736511 View Post
    You can get cable tensions and weight off the internet. Tension can be 100-500 lbs/sq ft for a transmission line. Weight for 1000MCM is 1.063 lbs per ft. If you don't care about accuracy, then just input any number and see if it looks good. When you figure it out for one, then you can use that same number for the other curves. Note that it doesn't change existing polylines. It creates new ones.
    C:> ED WORKING....
    LinkedIn
  1. 2012: Parabolic Ceiling Fixtures not illuminating
    By rc.246059 in forum Revit Architecture - General
    Last Post: 2011-10-15, 01:14 PM
  2. Ellipse / parabolic curve drawing
    By Richard McDonald in forum AutoCAD General
    Last Post: 2011-05-09, 08:07 AM
  3. Placing component "Troffer Light - 2x4 Parabolic"
    By buttonsrtoys in forum Revit Architecture - General
    Last Post: 2010-01-21, 12:05 AM
  4. Parabolic Curve
    By Roger Evans in forum Revit Architecture - General
    Last Post: 2005-01-12, 09:51 AM
Tags for this Thread
