Results 1 to 8 of 8
Thread: Slow Lidar
    2023-01
    67
    Default Slow Lidar
    Good morning.
    I'm having lidar polyline issues. I have downloaded the contours and they are ready to put in surfaces. The problem we have is that they are so slow to select which makes it almost impossible to use. Is there a setting that I'm overlooking that may help?
    TIA!
    2009-11
    5,780
    Default Re: Slow Lidar
    The issue sounds like it's due to each Polyline having many, many vertices - each of which is highlighted when selected as a Grip.
    Consider starting the desired Command then selecting the Polylines (which doesn't show Grips), or temporarily set GRIPOBJLIMIT sysvar to 1, which will disable Grips when more than one object is selected.
    Unfortunately, Autodesk has not provided a GRIPLIMIT sysvar that would limit the display of Grips when an entity has too many grips.
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2023-01
    67
    That seems to help a little. Thank you
    2014-08
    457
    hi, you might try weeding the vertices some sue the weedfeatures command.
    2009-11
    5,780
    Not sure where you downloaded the 'lidar polylines' (County GIS? )... but *IF* you could instead simply download the source Lidar, you could use DotSoft's LidarTools to more easily build a Surface from the source data, rather than a Polyline derived from same, which inherently has less detail throughout the resultant Surface.
    Computer Specs:
    2023-01
    67
    TY. I will give that a try.
    Turlock, CA
    6,586
    Quote Originally Posted by remi678731 View Post
    @Desirea. If you don't have C3D, you can check out these options.
    C:> ED WORKING....
    LinkedIn
    2023-01
    67
    Thanks! I probably should have mentioned that I'm using c3D 2025.
  1. LiDAR Data Support
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2012-08-02, 07:31 AM
  2. Lidar file format
    By jenniferchavez in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-02-24, 10:59 PM
  3. Slow.. slow..very slow..Gallery
    By engwaiphyo in forum AutoCAD Gallery
    Last Post: 2009-04-09, 07:32 PM
