Results 1 to 1 of 1
Thread: quick profile
    2004-06
    Slidell, Louisiana
    986
    Default quick profile
    I used to be able to create a 3d polyline, create a quick profile view, the export that as an xml file, then insert that xml file back into the dwg and it would create an alignment.
    then I was able to create a profile of that alignment (3d entity) and create a profile view that I could use in my dwg. For some reason that does not work anymore.
    the alignment does not show up in the toolspace and I get an aligment conflict in the panorama. anyone have the problem? or know what I might be doing wrong. I've used
    this method numerous times in the past and it has work without any problem.
    edit: found the problem. you have to delete the 3dpolyline or feature line before importing the xml file back in.
  1. 2017: Quick Profile crash
    By tadthurston725387 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2017-04-03, 08:15 PM
  2. Quick Profile View Elevation Adjustments.
    Last Post: 2015-07-16, 03:52 PM
  3. 2010: Properties and Quick Properties are gone from quick menu
    By daxxterrygreen822678 in forum AutoCAD LT - General
    Last Post: 2012-07-10, 08:56 PM
  4. 2002 quick save not so quick...
    By andrewp in forum AutoCAD General
    Last Post: 2005-11-17, 05:17 PM
  5. Fascia Profile (was>Quick Question.)
    By jakedanceparty in forum Revit Architecture - General
    Last Post: 2005-02-01, 01:00 AM
