Thread: POSGAR 07 Argentina
    2011-08
    7
    Default POSGAR 07 Argentina
    Hello, i need to know how to load POSGAR 07 on civil 3D, could someone help me please?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,168
    Default Re: POSGAR 07 Argentina
    Would that be the Argentina POSGAR Faja 7, 54 deg West system? It is listed as one of the systems in the Argentina categories. You may also type FAJA-P7 into the Selected coordinate system code: text field. All of this can be set using the Units and Zone tab of the Drawing Settings dialog box. You can access the Drawing Settings dialog box by selecting the Settings tab of the Toolspace palette and then right-clicking the drawing name to select the Edit Drawing Settings... option.
  1. 2015: Sistema de coordenadas Posgar 07
    By walter.mardones556715 in forum AutoCAD Civil 3D - General
    Last Post: 2014-10-24, 04:08 PM
Tags for this Thread
