Thread: Embedded Raster Image
    2007-07
    399
    Default Embedded Raster Image
    I just discovered that my embedded raster image prints out (in pdf) upside down when my drawing is not in world coordinate. It looks right in the drawing, even looks right in the print preview. The only way I could find to fix it is to rotate my drawing to WCS. Does anyone know of a better way? Thanks.
    PS the way I embedded the image was to open the jpeg image in Paint, copy all and paste special into dwg as a Picture (Metafile).
    Turlock, CA
    6,517
    Default Re: Embedded Raster Image
    Is the picture bitonal? If so, you can use the RasterDesign IEMBED command to embed the image. Perhaps that will give different results.
    C:> ED WORKING....
    LinkedIn
    2007-07
    399
    It's not bitonal - I'll just have to rotate to WCS
    Thank you!
  1. 2017: Slide from embedded image
    By paulof in forum AutoCAD General
    Last Post: 2016-10-13, 03:11 PM
  2. 2015: Insert image, unload image, image border stays around
    By invaderkyle in forum AutoCAD General
    Last Post: 2015-04-10, 03:23 PM
  3. Replies: 0
    Last Post: 2013-04-10, 02:25 AM
  4. Embedded Raster Images
    By dbeavers in forum DWG TrueView - Wish List
    Last Post: 2009-07-27, 11:11 AM
  5. Image embedded in detail component and it just wont work...
    By PeterJ in forum Revit Architecture - General
    Last Post: 2003-08-01, 08:03 AM
