Results 1 to 6 of 6
Thread: Set Feature Line Default to Elevation
    2023-01
    61
    Default Set Feature Line Default to Elevation
    When creating a feature line I am prompted to enter an elevation on my first point but after I enter the elevation, the prompt asks for a grade next. This is so frustrating when you don't remember to change it back to elevation. Does anyone know if there is a way to set the default to continue the prompts for elevation?
    2014-08
    452
    Default Re: Set Feature Line Default to Elevation
    hi
    read the command line prompts you can change it each time and it holds the last input
    2023-01
    61
    I do it that way but wondered if there was a way to change the default.
    Earth
    9,823
    You would probably have to roll your own "make feature line" command.
    Some sample code that may get you headed in the right direction is here.
    R.K. McSwain | CAD Panacea |
    2023-01
    61
    Thank you!
    2024-07
    set your OSNAPZ to Zero and it should remember the elevation of the point, then E for elevation (will also remember the elevation of the point).
  1. 2021: default Feature line style
    By tim_newsome in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2021-08-30, 06:36 PM
  2. 2015: Feature line Elevation Controls
    By MMccall in forum AutoCAD Civil 3D - Grading
    Last Post: 2017-01-24, 06:00 PM
  3. 2015: Feature Line picking up intermediate elevation points.
    By jlpage3710043 in forum AutoCAD Civil 3D - Grading
    Last Post: 2015-10-01, 03:17 PM
  4. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
  5. Default Feature Line Style
    By Civil Samurai in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-19, 12:45 PM
