Thread: transfer multiple blocks
    2004-06
    Slidell, Louisiana
    983
    Default transfer multiple blocks
    How do I transfer multiple blocks from one dwg to another.
    I have numerous blocks in an old template dwg that I want to transfer
    to a new template dwg. Design center will not let me copy all the blocks at once.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,167
    Default Re: transfer multiple blocks
    You may need to write all of the blocks out as individual drawing files. You can then insert the necessary blocks into your new template. This routine can write each block out, however, you may be prompted to export Map features for each block. I think that is mentioned later in that thread.
    Turlock, CA
    6,526
    Another low-tech way is to insert the dwg that contains the blocks into the desired dwg, then explode the "block" dwg. Or use CLASSICINSERT and select the file to insert, hit OK and at the prompt to select an insertion point, hit {ESC}.
    C:> ED WORKING....
    LinkedIn
  1. Multiple video screen part transfer to other drawings
    Last Post: 2018-10-18, 10:01 PM
  2. Replies: 2
    Last Post: 2017-03-08, 06:27 PM
  3. transfer blocks to excel
    By z_ayri788300 in forum AutoLISP
    Last Post: 2012-10-15, 12:33 PM
  4. Transfer Level Bubble Alignment.
    By bclarch in forum Revit Architecture - Wish List
    Last Post: 2003-06-17, 02:24 PM
  5. Transfer project standards - and overwrite!
    By Wes Macaulay in forum Revit Architecture - Wish List
    Last Post: 2003-05-27, 12:34 AM
