Thread: What 11 x 17 Printer
    2024-07
    Default What 11 x 17 Printer
    I am just starting a single person civil engineering site design firm. For the time being, I will be printing 11" x 17" paper format as my standard drawing size. However I'm also doing design for clients using an outside support drafter that uses AutoCAD ( don't know the year) He draws a drawing on a 22" x 34" format and reduces for printing - 50%. He then sends me a PDF file of the drawing and I'm having to use the local library to print. MAJOR ISSUE: using his file and printing at fit to page setting , I don't get a correct scale. BUT When selecting page type, I can't select "Original Size" or anything but shrink to paper size.
    How can I fit it so the print is to size? What 11 x 17 all-in-One printer is going to work??
    Thanks from a newbie.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,192
    Default Re: What 11 x 17 Printer
    This is more of an Adobe or other PDF software printing question.
    In Adobe, you should be able to specify the size of the print as a percentage for a custom scale. For a 22"x34" sheet, the 11"x17" sheet size would need a 50% reduction. Of course, depending on the printer, the margins of the printable area may make this reduction not exact fit the printable area of the paper.
    Turlock, CA
    6,576
    Are you saying that the pdf he sends you is already at 50%. Then you should print at 100%, not scale to fit. This should resolve the issue of different printer margins, as Opie mentioned.
    C:> ED WORKING....
    LinkedIn
  1. Default Printer when opening drawing with unrecognized printer
    Last Post: 2014-05-19, 10:45 AM
  2. Printer Set to Sheet
    By Henry D in forum Revit Architecture - Wish List
    Last Post: 2007-02-27, 04:04 AM
  3. 11x17 or larger Printer
    By Les Therrien in forum Revit - Hardware & Operating Systems
    Last Post: 2004-09-01, 03:32 PM
  4. printer/plotter
    By cgrover in forum Revit - Hardware & Operating Systems
    Last Post: 2004-02-05, 04:33 PM
  5. Forum Update: Printer Friendly Topics
    By christopher.zoog51272 in forum Announcements
    Last Post: 2003-05-06, 02:26 PM
