Thread: Surface from XML is telling me there is something wrong with the definition
    2023-01
    60
    Default Surface from XML is telling me there is something wrong with the definition
    I imported a surface from one file to another using an xml file. Now the surface in the file I imported to is saying something is wrong with the definition. I had the xml file on my desktop and then deleted it because it was just temporary. Is the xml file attached somehow to the surface? If so, is there a way to change it?
    Thank you!
    2014-08
    452
    Default Re: Surface from XML is telling me there is something wrong with the definition
    Did you use XML or LandXML
    2023-01
    60
    Quote Originally Posted by remi678731 View Post
    I didn't realize there is a difference. I used Landxml.
    9,821
    Have you checked the Event Viewer?
    Does it contain an error like this?
    https://imgur.com/bG8KQY6
    This link https://help.autodesk.com/view/CIV3D...A-E96FBD1399DB
    Says you need to turn on Snapshot creation so that it won't look for the XML file each time
    2023-01
    60
    I haven't but I will take a look. Thank you!
    2018-11
    Quote Originally Posted by Desirea View Post
    Thank you!
    Yes, the surface does reference the .xml file. I suggest saving it to the server so others will have access. You can repath it in the Surface properties dialog box, the Definition tab. You'll see it listed under Operation Type.
  1. Replies: 0
    Last Post: 2014-11-17, 06:05 AM
  2. Dimensions not telling the truth
    By Mike Sealander in forum Revit Architecture - General
    Last Post: 2012-07-14, 11:15 AM
  3. Stop Telling me file needs to be saved
    By kspear in forum Civil 3D Wish List
    Last Post: 2012-02-20, 04:23 AM
  4. Telling the difference between 32 & 64bit
    By Ferroequine in forum AutoLISP
    Last Post: 2010-05-06, 06:35 PM
